MNSBR: Yamaha R7R Build - MNSBR
Yamaha R7R Build
#1 User is online   Foss Icon
  • Ride:FZ07R
Posted 04 January 2019 - 03:05 PM
Time to make this project official. After buying a salvage FZ, building it into a track bike, and racing it for a while I fall in love with the power and sound of this motor. I've debated getting another for street duty, but I just can't quite get over the look and riding position. I equally enjoy my R6, but most of the fun comes with high RPM and MPH that I have less interest for these days even on county back roads. The goal is simple: take two bikes, tear them apart, mash parts together, and hope for greatness. Hopefully the end result is a torquey twin with sportbike aesthetics.
It took a while watching the market to find the right R6 donor bike. Top choice was something with a blown motor and thrashed bodywork so I could make it look my own without spending a ton or having to mess with parting anything out. Found a couple candidates over the summer with torn up fairings but running motors that were close to coming home. A couple weeks ago I found this gem. Frame, forks, and wheels appear straight, but most everything else is "well worn".
Attached thumbnail(s)
  • Attached Image: 1.jpg
  • Attached Image: 1a.jpg
  • Attached Image: 1b.jpg
  • Attached Image: 2.jpg
#2 User is online   Foss Icon
  • Ride:FZ07R
Posted 04 January 2019 - 03:12 PM
Celebrated New Year's in the garage tearing down the R6 and pulling the motor out of the race bike for mock up. Once/If this works, I'll probably look for a salvage FZ to harvest the motor, wiring harness, ECU, and cluster from so I can put the race bike back together. Seemed foolish to make that investment up front. Worst case right now I can get my money back out of the R6 by selling the frame/forks/wheels if I have to.
  • Attached Image: 3.jpg
  • Attached Image: 4.jpg
#3 User is offline   macs pal Icon
  • Holy hell......Get me out of here!
  • PipPipPipPipPipPipPipPipPip
  • Interests:Shuffel board
  • Ride:Aprilia RSV4, Triumph 675, Yamaha Yz250f CRA # 811
Posted 04 January 2019 - 03:34 PM
Very cool
#4 User is offline   POE Icon
  • Ride:600RR x3
Posted 04 January 2019 - 03:45 PM
+1
Awesome project! I naturally assume that you and Moto America BLR Team Owner are sharing notes along the way?
#5 User is offline   re tired Icon
Posted 04 January 2019 - 04:52 PM
Yes!
Finally, a bigger idiot.
This is gonna be fun.
  • Attached Image: nS5IdXB.gif
#6 User is offline   crakerjac Icon
Posted 04 January 2019 - 06:08 PM
Following. This project is right up my alley.
#7 User is online   Foss Icon
  • Ride:FZ07R
Posted 05 January 2019 - 05:35 PM
Built a quick template to get an idea how far off the mounts are without having to muscle the engine around. Initial thought is to use the lower rear mount direct engine to frame and make brackets for the other three.
  • Attached Image: 20190103_160213.jpg
  • Attached Image: 20190103_154003.jpg
  • Attached Image: 20190103_154023.jpg
  • Attached Image: 20190103_160338.jpg
#8 User is online   Foss Icon
  • Ride:FZ07R
Posted 05 January 2019 - 05:53 PM
At this point my biggest concern was sprocket height. Some rough measurements with engines on the floor had the FZ sprocket around 3/4" lower/closer to the bottom engine mount. That much difference would have resulted in at the very least, excessive chain wear on the guide, and I would assume other negative impacts. It was hard to measure accurately without knowing exactly how the engine would be clocked in the frame. The further it's rotated clockwise, the higher the sprocket is. Starting to worry using the lower mounts direct might not be an option, I decided it would be best to swing the engine in and take a closer look. Built a quick jig based on the R6 motor that used the two rear mounts and centered a bolt on the sprocket. Sliding that over the frame with the FZ motor in place shows it's a lot closer than I thought. Might be able to get the engine rotated a bit more with a little grinding, but I'm not sure the gains are worth it.
  • Attached Image: ATT00001 (14).jpg
  • Attached Image: ATT00001 (15).jpg
#9 User is online   Foss Icon
  • Ride:FZ07R
Posted 05 January 2019 - 06:09 PM
Cut some metal today. Upper/Front mounts are coming together nicely. Motor now sits in place solid without straps/jacks/etc. The difficult part is going to be coming up with measurements for spacers to accommodate the offsets on each side of the flat stock while keeping the engine straight in the frame. Can't just measure it sitting in the frame as you can still torque the engine slightly. It doesn't take much flex to result in a few millimeter change in spacers. Maybe that wouldn't amount to enough sprocket angle change to worry about?
  • Attached Image: ATT00001 (11).jpg
  • Attached Image: ATT00001 (13).jpg
  • Attached Image: ATT00001 (17).jpg
#10 User is online   Foss Icon
  • Ride:FZ07R
Posted 05 January 2019 - 06:14 PM
Doodles
  • Attached Image: ATT00001 (18).jpg
#11 User is offline   re tired Icon
Posted 05 January 2019 - 08:01 PM
All hail the new King of Schwing!
Love it!
Old school, no calipers or micrometers here folks, just a precision wooden Lego set.
My kinda engineering.
#12 User is online   Foss Icon
  • Ride:FZ07R
Posted 05 January 2019 - 09:16 PM
Love it!
Well......once I started metal today I broke down and went calipers, degrees, millimeters, and of course a few choice words when I messed up the math and had to remake a bracket. Kids spent a good 2 hours in the shop adding nails, screws, and rope to my wood Lego set. It's now a certified bird trap hanging in our front yard.
#13 User is offline   re tired Icon
Posted 05 January 2019 - 10:59 PM
Major Kudos to you for even trying this.
I'd still be flailin about the shop swatting at flames, lol.
#14 User is offline   POE Icon
  • Ride:600RR x3
Posted 06 January 2019 - 03:11 PM
Love it!
A big +1 to that
:lol2:
Really excited to see how this turns out! (And to see it on the LWGP grid! Posted Image )
#15 User is offline   Champ Icon
Posted 07 January 2019 - 07:00 AM
Gorgeous
