MNSBR: 2009 Kawasaki ninja 250 - MNSBR
#1 User is offline   CBR600F4i Icon
  • Always Along For the Ride...
  • PipPipPipPipPipPipPipPip
  • Ride:Super duke, SV650, Grom
Posted 27 July 2020 - 06:38 AM
2009 Kawasaki Ninja 250R
Fully built CRA race bike
Almost new Dunlop Slicks
Extras:
Steel Vortex 44 tooth rear sprocket
Stock ecu
Frame caps
PIT BULL TRS PINS
Mortex oil
Ecu tuner
Built by Sam DeMiller at Starr Cycle in mankato MN
Build list below:
--Engine:
'09 with Stock internals and airbox as required by rules
Area P high flow race system with 18" carbon can
UNI Air Filter
Dynojet needles, factory Keihin jets
KG Factory Kevlar clutch plates, OEM steels
Kreiger manual cam chain tensioner
NGK CR8EK spark plugs
PSR smog block off plate
Radiator fan removed
Thermostat removed
Thermoswitch replaced with plug
Aluminum magnetic drain plugs
Motorex Crosspower 4t 10w50
--Suspension, Drive and Brakes:
Ohlins shock w/ carbon resivor bracket
Titanium shock mount bolts, KTM leftovers
Race Tech cartridge emulators
Race Tech .80 fork springs
Motorex 15wt fork oil
All Balls tapered roller steering head bearings
SSR adjustable preload fork caps
Braking SK2 floating front rotor
Galfer steel front and rear brake lines
EBC HH brake pads
Motul RBF600 brake fluid
Captive rear brake hanger mod
"Oaksterdam" lightned rear rotor
Graves rear brake lever return spring kit
Driven sprockets 14-42
--Chassis and Controls:
Woodcraft clipons
Renthal road race grips 32mm
Woodcraft rearsets
Yamaha TW200 shift lever mounted backwards for GP shift
G2 Ergonomics perch spacer for front master cylinder
Cycle Pirates billet race throttle kit
CRG Roll-a-Click knockoff levers
KTM Powerparts front brake lever guard
ZETA rotating perch clamp on master cyl
Orange powdercoated frame
Custom adjustabe steering stop bolts
Custom in house made ultra light fairing bracket
Hotbodies bodywork and windscreen
Motoseat seat cover
Worldwide ceramic wheel bearings
Custom shortened choke cable, near carbs now
--Electrics:
Trail Tech Stealth Vapor guage with all functions active
Custom in house made carbon dash panel
Custom oil pressure warning lamp
Custom in house made race wire harness
Toggle ignition switch
Shorai battery
K&S start/stop/run switch
Price $1800
3 User(s) are reading this topic
0 members, 3 guests, 0 anonymous users
