MNSBR: Ktm Leaky Fork Seals - MNSBR
#1 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 10 February 2016 - 12:45 AM
Recently replaced the fork seals and bushings on KTM 250 and they leaked like hell when I rode last time. By leak I mean almost dripping (could feel the oil at the bottom of the forks after riding). After the ride, used the seal mate and that seemed to stop most of it. We will see when I get her out again.
Do you guys ever have a fresh set of seals leak for the first few rides or so (maybe the lips aren't sealed properly)? I'm fairly certain they are not upside down so let's assume that's not the issue
Bought the bike used and abused so I can't rule out dented forks etc. except that before only one seal leaked and now they are both about the same.
#2 User is offline   Aprilian Icon
  • Caution, Race Track Ahead!
  • PipPipPipPipPipPipPipPipPipPipPip
  • Interests:Helping people who run out of talent before they run out of horsepower!
  • Ride:Street Triple R
Posted 10 February 2016 - 08:21 AM
did you grease the seal lips?
#3 User is offline   TLRSKUNK Icon
  • Ride:16 R1 60th Anniversary, 2010 YZ450 Sumo/dirt, 15 Grom
Posted 10 February 2016 - 08:43 AM
Did you buy "Leak Proof" brand aftermarket seals? or stock ones?
Did you grease them upon install? Torn seals during install is a very common issue.
#4 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 10 February 2016 - 01:53 PM
I rubbed some fork oil around the lips of the seal, and used electrical tape over the lower ridge that holds the bushings to avoid damaging the seal as I slid it over.
I bought moose seals which I've used before without much issue
#5 User is offline   JVS Icon
  • PipPipPipPipPipPipPipPipPipPipPipPipPipPipPip
  • Ride:03 R6, Ssr125
Posted 10 February 2016 - 02:11 PM
No job in kyles garage is complete without electrical tape.
#6 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 10 February 2016 - 02:12 PM
You're damn straight
#7 User is offline   Aprilian Icon
Posted 10 February 2016 - 05:19 PM
oil and grease - no difference as long as it comes from a dead dinosaur
perfectly interchangeable with no impact to results, right? :bankhead: what weight grease do you use in your engine? :confused:
#8 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 10 February 2016 - 05:40 PM
Good point, I probably should have used the same grease I use when putting my oil drain plugs back in. My bad
#9 User is offline   JVS Icon
Posted 10 February 2016 - 05:51 PM
Just mix some gorilla glue in the fork oil. Homemade stop leak. Boom.
#10 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 18 February 2016 - 09:54 PM
Ok, so I'll admit I must have fucked up something. Both seals leak like JVS after watching gay porn.
To those knowledgeable, please edumacate me as to the proper way to do seals. I guess I need the pro tips since I can obviously change them, but messed up along the way. Examples include brands to look for, greasing, etc. I'm done messing around, just want to do it one more time and be done.
And no, I'm not taking it in
#11 User is offline   JVS Icon
Posted 18 February 2016 - 10:05 PM
From their website:
"If zip ties, duct tape or a hammer can't fix it we probably can't either"
-KylesGarage.com
Sounds like you should just take it in. Your good at that anyways.
#12 User is offline   metalhead Icon
  • Ride:06 GSXR 600
Posted 18 February 2016 - 10:50 PM
I had the exact same thing happen when I had a set in upside down, I would pull them and double check they aren't upside down.
#13 User is offline   smokinsingle Icon
  • 33E
  • Interests:SUPERMOTO
  • Ride:NINJA 250R, KTM 950 SMR, 450 SMR, 300 MXC,
Posted 19 February 2016 - 05:57 PM
If they are 48mm ditch the Moose triple lip and go with the green SKF seal from KTM, pn 48600969. Best seal by far.
#14 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 19 February 2016 - 07:14 PM
Thanks for the tip, I'll look into it
#15 User is offline   zxGran Icon
  • RIP Ninjas
  • Ride:CRF 230
Posted 24 February 2016 - 09:18 PM
Update, pulled the forks apart and upon inspection, realized the support rings for the outer tube bushings were bent on both forks (the angle looked like they were both supposed to be that way). If the bushings didn't seat, I wouldn't expect the seals to seat either so I think I found the issue.
Going to replace everything, bushings, seals, rings, etc with KTM kit and will update afterwards.
3 User(s) are reading this topic
0 members, 3 guests, 0 anonymous users
