MNSBR: Tube AND tubeless - MNSBR
Tube AND tubeless not a comparison
#1 User is offline   Turner Icon
Posted 02 January 2019 - 02:15 PM
Theres tubeless tires and tube tires...
I'm looking for input on doing both
and by both I mean;
Using a tubeless designated tire, with and inner tube, and having both inflated at 30-35 psi/separately.
#2 User is offline   Champ Icon
Posted 02 January 2019 - 02:21 PM
Not sure what it would accomplish - and you'd have to drill a second hole into the wheel casting (for the tube's valve) and somehow seal that from the tubeless portion's pressure so it didn't leak out.
What do you think you'd gain by doing this?
#3 User is offline   Jim Icon
  • I'll believe it when I prove it myself.
  • PipPipPipPipPipPipPip
  • Interests:Data Acquisition
  • Ride:Whatever you'll let me.
Posted 03 January 2019 - 08:31 AM
Belt and suspenders?
One of the advantages of tubeless tires is that there was no longer a tube to chafe against the inside of the tire. This chafing inevitably caused a temperature rise.
I have no doubt the rubber formulation of tubeless tires is optimized with the idea there will be no chafing (hence, no temperance rise from this source).
#4 User is offline   re tired Icon
Posted 03 January 2019 - 09:14 AM
Or is it 'jumping as the elevator stops'?
I don't think you can do both. If you have an empty tube in a tubeless tire, inflate the tubeless tire to 35psi, then try to inflate the tube, you'd go well over 35psi before you got the tube inflated. Hmmm...?
Interesting, brain freeze.
#5 User is offline   POE Icon
  • Ride:600RR x3
Posted 03 January 2019 - 09:34 AM
If each were inflated to the same PSI, the innertube would not really be inflated at all. Same as it would be in normal atmospheric pressure sitting on a self with no valve stem core. If it had any pressure greater than the surrounding pressure, then it would start to inflate into a smooth non-squished tube.
I'm also curious where this is going...
#6 User is offline   Vrooom Icon
  • Its coming rite at me!!!!!!
  • Ride:sold !2012 Gsxr 750,sold!2011 Ninja 1000 Sport tour thang"sold" ,09 Ktm 690 SMC Vrooom Vrooom!!! 06 Red GSXR 750 Sold!!!, 11 YzF 450 SuperTard/Mx
Posted 03 January 2019 - 10:57 AM
I know on mtb tires you run Stans or orange seal in case of a flat. Could you just run Green Slime or would that throw the balance off on the tire?
#7 User is offline   Turner Icon
Posted 07 January 2019 - 12:05 AM
Having only a tube is prone to expelling all the air from the tire at once. A tubeless tire seems like the better option for the sake of a slow leak with a puncture, less rotational weight, and no chafing.
Inflating the outer carcas (first) to 35 p.s.i. then inflating the tube to 35 p.s.i. would create an additional pressure between the inner and outer. (Inner tire size/ diameter/ volume displacement/ outer tire volume/ ummm math??) I was thinking inflating the inner tube first to 33psi, then the outer tubeless tire to 35 psi, creating a 2 psi difference at temperature as an extra coushin over rough spots. (The suspension on the bike should start to compress before this comes into effect.)
no slime just to avoid any type of chemical in and around the tire.
Brings me to the idea of ice-screws inserted in the outer tube. How do these guys run without losing air and hundreds of puncture spots?
(For the record, I'm getting me some D404s, rim strips, and calling it a day.)
#8 User is offline   POE Icon
  • Ride:600RR x3
Posted 07 January 2019 - 09:03 AM
They use a backing material of some kind underneath the studs/screws. This has two purposes, it can give the screws more substance to bite into and also protects the innertube from screw/stud punctures. They do use innertubes, but they do not inflate the tubeless tire, only the inner tube.
Some guys will cut an old street tire to remove the side walls and use the center tread as an insert to the ice tire for backing material to sink screws into and a buffer for the inner tube.
#9 User is offline   WillMill Icon
Posted 07 January 2019 - 12:16 PM
There is also a 3rd purpose to the extra rubber inside the tire. Extra rotating mass, it keeps the bike more stable sliding around the corners. Flat track guys will add wheel weights inside the rim to accomplish this.
#10 User is offline   POE Icon
  • Ride:600RR x3
Posted 07 January 2019 - 12:18 PM
Ah, cool, I did not know that.
#11 User is offline   WillMill Icon
Posted 07 January 2019 - 12:22 PM
I don't think adding wheel weights is AMA legal though, lol. There is definitely a maximum wheel weight for flat tracking because heavier wheels do offer an advantage.
4 User(s) are reading this topic
0 members, 4 guests, 0 anonymous users
